Behaviour Model for 8-bit Ideal DAC
snoop835
Full Member level 1
Penang, Malaysia
hspice ideal dac
Hi everyone!
I wanted to investigate R2R 8-bit DAC performance i.e. Gain Error. To do this I need compare the actual DAC slope vs ideal slope. Now I will need to create a netlist for 8-bit ideal DAC using Star-HSpice. I have some reference SPICE netlist to generate ideal slope. However when I tried to run using STAR-HSPICE, it won't work.
I got the reference netlist from:
Is this a correct way to investigate the DAC performance in time-domain analysis? Can you guys suggest any good reference on how to generate ideal 8-bit DAC using Star-HSPICE?
Many thanks..cheers
hspice ideal dac model
use E.. elements
ideal slope dac
Thanks for the tip flushrat. But I still couldn't get what do you mean by using E element. I think i need to modify the switches for use in Star-HSPICE, since it doesn't recognise model VSWITCH.
Anyone has good suggestion on this?
cheers
