Beginning USB Pic Programming
aersoy
Member level 3
Member level 3
ankara turkey
Hi, i want to start learning usb pic18F programming, but i dont know where to start. Can you give me some advises, links, books names etc.
USB complete by Jan Axelson is a very good book which covers both, PC and Microcontroller. The PC code is described in the book in VB and C#.
The Author also has downloads to example code on her website, which is where I began, If you dont mind coding in C# **broken link removed**
For the PIC side of the design look at the the examples which came with your compiler. I use the PCW compiler which has some good human interface device examples.
You need to understand the USB descriptor tables, there are some good online resources too. Try "usb in a nutshell" or "usb made simple"
Reactions: aersoy
    aersoy
The Microchip provide a wide range of application notes and sorces and example codes for the USB appliication. Better to serch in the microchip webpage
Try this simple tutorial,
Thank you,
