wider than what?. In any case, to make the beamwidth wider you have to make the antenna smaller. to do this you can choose a dielectric substrate of larger permittivity, which makes the antenna to be electrically smaller.
be careful because this heigher eps makes the quality factor of your antenna larger, which means that the input bandwith is narrower!!
