[SOLVED] BCM4325 how to use???
mohamed.elsabagh
Full Member level 2
Full Member level 2
can anyone give me help on how to use BCM4325 IC? I can't find datasheet or any application note, just a product brief. Can i use to interface with a controller and control sensors through wifi or bluetooth?
Hi, did you try to look for the similar model of the IC? just do a search online and sometimes there will be a replacement model for a particular IC.
yes but still can't find any technical data, very strange!! how would designers use this chip
what does this means??so how can designers use their chips in their projects?
You will have to contact Broadcom to get the datasheet (assuming they will give it to you). They may only supply it under an NDA.
Keith
so can anyone recommend cheap bluetooth + wifi module i can use instead
