Wessex
Newbie level 5
hi
am using a MC14520B BCD IC, which according to its waveform diagram, counts up to 0-15 decimal.
I have built a test box, 555 timer generating 1hz clock , into BCD IC, then out to ADG406 multiplexer
test box is used to check 14 way multicore cable, each output from mux is connected to one end of cable, molex connector, then other end is connected to LED.
idea is , LEDS in box scroll on off individually, in squence, showing cable is connected correctly pin to pin.
what we observe at minute, is the MC14520B only seems to count to 8 ?
have i missed some connection out, does anyone have experience of using this IC ?View attachment mux schematic 5.8.12.pdf
