baud rate calculation for PIC
jerkymotion
Member level 4
Member level 4
NEPAL
what is baud rate and what is it's significance in microcontrolller
how to calculate the baud rate for pic16f877a .....
Baud rate defines the speed of the data. it defines the rate of change of signals per second.
Measure for data transmission speed, which shows the number of signals transmitted per second. It is roughly equivalent to bits per second (bps) and the two terms are often confused. There is a difference as bits per second shows the actual number of bits transmitted, while baud rate shows the number of signals transmitted and each signal can represent more than one bit of data. Baud rate and bps coincide only for low rates.
