rajaram04
Advanced Member level 3
Hello sir
I ve two batteries of 4 volts 1 amp & i am connecting them in series so as to obtain 8 volts
Now i am connecting several White LEDs in parallel & each LED is having a serial resistor of 220 ohms 1/4 watt
Here i am getting sufficient bright light .
Now i am replacing both the batteries with 4 volts 2 amp.
So in this case what would be the resistor parameter ?
is the value remain same ?
