fakhry2002
Member level 2
Dear All
I'm going to build my 1st UPS it's rated 500 Watt
I'm using a Push Pull DC-DC converter to step up battery up to 300volt
I'm using only 1 battery from powersoinc
the battery specs is 12 volt 8 AH
i found the Push pull satge will need a Peak current about 70 A ( 80% duty cycle, 90% effeciency, 300v/500 watt output)
my question is
dose this battery could supply this 70 peak current or not???
do u have any suggetion for the battery??
the 8AH battery datasheet is attached
thanks
my question is
thanks
