James_Watson
Newbie
Hello.
I want to design a current limiter for a battery powered project.
Battery will work at 42V when is fully charged and 30V when is discharged.
I want to limit the output current of the battery in 2 or 3 different values, depending the use, at 2 amps, 4 amps and 6 amps (with a potentiometer or different resistors).
Any help about which componets or integrated to use?. I have made some tests with mosfets, but the problem is the voltage changes between 42V and 30V and the current has not a fixed value when battery volatge changes.
Thanks for your time.
