moonloopsun
Newbie
Hi guys,
I am new here and still not an engineer and have not much knowledge in Battery / electricity but have a major project I am working on and would be very happy to get some answers..
I am trying to build a machine that is using a spin motor that work periodically in set times (650 spins a day: 10 turn per minute than a few minutes rest) by a simple electric circuit and position it in a place without electricity connection.
The manufacture of the motor sent me these consumption values: Voltage: 3 - 12VDC, Current @ maximum efficiency: 0.17A. On the machines provided power supply I have the follow values: 3v / 1.2A
They also claim that when it is operated by strong 2 x AA batteries it will be able to work for around 8-9 weeks (defined amount of movements periodically in a day - around 650 turns total).
I try to find a way to operate the machine longer without any need to change the batteries every second month.
I try to look at a solution of connecting a 40000mAh portable usb power bank to it through a 'step down voltage device' that will provide it the right amount of Voltage and Ampere.
Like this one:
My questions are:
Is it true that in these settings with a 40000mAh power bank, the machine will be able to run 20 times longer than when it will when running on 2x AA 2000mAh batteries ?
Is it safe to have the machine connected to such a power bank constantly and have it stored in a close place ?
Thanks a lot for your time !
Like this one:
PEMENOL DC DC USB Step Up Down Stromversorgungsmodul: Amazon.de: Computer & Zubehör
PEMENOL DC DC USB Step Up Down Stromversorgungsmodul Grüne LCD Anzeige Einstellbar Buck Boost Converter 5V bis 1V-24V Step Up Down Modul mit Mit Schutzhülle - Kostenloser Versand ab 29€. Jetzt bei Amazon.de bestellen!
www.amazon.de
My questions are:
