battery chargers - AGM and lithium
bobdxcool
Member level 5
I am working on an inverter with a battery charger for a 24V,200AH AGM battery pack. The battery charger current can be adjusted from 10 to 50 amps. Now, I want to be able to also a charge a lithium battery (24V,150AH) with this charger. Since the lithium iron phosphate battery has a BMS along with it which will prevent over charging and over discharging and also controls temperature, I can use a normal charger, right ? without a cell balancing module in the charger as the BMS takes care of it ? I need to only be able to adjust the discharge cut off voltage and charging cut off voltage for the entire 24V battery pack as per the manufacturer's data sheet. The lithium battery I am talking about there is one which has BMS integrated inside the battery pack.
