thedarkhorse
Newbie level 2
i m designing battery charger of 48v,50A as load.for that we used IGBT for triggering device.we need to generate PWM using dsPIC3011 to trigger IGBT.i did the programming part but in wrong way.i want any sample PWM generation code in embedded C language.if anyone has it pls give me.
also is there any power transducer which can convert three phase supply to dc 5V.because i need to give this voltags and current values to dsPIC 3011 for display purpose and feed forward mechanism.
