battery charger using circuit maker
rawanayyoub
Member level 1
Member level 1
Husn, Jordan
Hi all,
please i need to make simulation to the attached circuit using circuit maker 2000 student edition , this circuit work as automatically emergency lighting circuit when power outages.
Thanks in advance
Rawan Ayyoub
Are you asking whether the software is able to read a schematic diagram, and interpret it, drawing components automatically, with the correct values, and wiring them together, thus converting a diagram into a simulation?
You may find it does not have that ability. You probably need to do everything yourself, manually laying out each component, each wire, etc.
