henryuan
Newbie
Yes, it is a 24V NMC battery, the charger should be 29.4V, According to the capacity 10Ah, charing current can be 2-5A.
When not in use for a long time, it should be charged from time to time, although the BMS has over-discharge protection, if the time is too long, the BMS will not be able to prevent self-discharge and the battery will die.
Suggest you henryuan 29.4V 5A lithium battery charger. It is an intelligent three-stage charger that can charge according to the battery status. Keep your battery in perfect condition without overcharging.
https://www.henryuan.com/e_products...5A-Charger-For-7S-24V-Li-Ion-Battery-257.html
