teodor
Junior Member level 1
I'm designing a portable, for non-professional use, multi-chemistry Battery Charger. The device also can be used as Programmable Power Supply. It is based on SMPS. Mains Voltage - 230VAC/50Hz, ,output power - 150W max, consumed AC power - 180W max, cos_ph =0,65-0,70 (measured,currently without PFC). According to EN61000-3-2 harmonics directive, in which class of equipment this device should be included? And also, which other EN standarts should confirm? Thanks!
