viperpaki007
Full Member level 5
Can any body tell me that what is the difference between the charging procedure of Lead Acid, Nicd and NiMH batteries...Is voltage sensing of battery enough for designing a battery charger or current limiting should also be incoporated. and if so what is the recommended current and voltage levels for different kinds of batteries.
I also need to to the what is the difference in charging procedures of Fast chargers, Trickle chargers and normal chargers.
I hope that you people will suggest me some answers...
