Battery Charger circuit Required
kg300
Member level 3
Member level 3
RY Khan - PAK
Hello everyone,
I have a Led-acid Battery with 50-Amp and 12-Volt. Can anyone tell me the circuit diagram to charge this battery. it's best if it is Automatic, i mean when battery fully charged it automatically cut-off power.
I shell be very thankful.
There are many solutions to do this.
Try search for ''car battery charger'' on the net.
You have open the same discussion here
and my first idea proposed it’s old style solution... :D
Instead of liner transformer you can use SMPS power supply, then a battery charge management IC.
