does this mean that a minimum of 18.7V (Which obviously wont be the output of 12V reg) is required at the input of LM317 to work?
If I connect 3 CMJH180 diodes in parallel at the output of 12V reg without any resistors and then connect the battery via diode to the input of same 12V reg (which is also connected to output of bridge & rectifier appr. 20-30V DC) then would this solve all the problem?
if I want to use the same setup with three diodes in parallel (52mA) at output of 12V reg for another circuitry that is using nine 1.2V batteries in series (10.8V) 2000mAH NiMH)
Would there be any adjustments required in the circuitry? Again this battery would be connected for an indefinite period of time to the charger? Would 12V charging voltage too much for 10.8V battery? Could the battery pack be damaged using this configuration? Please advise
Syncopator is right. 12V is to low to charge a 12V battery. You need another 13.5V to charge the lead acid battery. To this, you need either another voltage regulator set to 13.5V. You can use the LM317 and set it to 13.5V output. The LM317 is powered from the 30V input. The LM317 output is connected to those three current limiting diode to the battery. Note the 12V DC is not used for charging the battery.If I connect 3 CMJH180 diodes in parallel at the output of 12V reg without any resistors and then connect the battery via diode to the input of same 12V reg (which is also connected to output of bridge & rectifier appr. 20-30V DC) then would this solve all the problem?
For your NiMH batteries, you charge it from the 13.5V with current limiting diode. You can charge NiMH at 0.05C indefinitely without damage. 0.05C is equal to 100mA. Your battery charger circuit is only 54mA.Secondly if I want to use the same setup with three diodes in parallel (52mA) at output of 12V reg for another circuitry that is using nine 1.2V batteries in series (10.8V) 2000mAH NiMH
(Duracell | Batteries | Rechargeable Batteries | AA Rechargeable Batteries | NiMH Rechargeable Consumer Style Batteries & Chargers |5000394203853)
Because the charger is voltage limited .....
