[SOLVED] Basic Serializer Verilog
stark43
Member level 1
Member level 1
Hello everyone. I'm new to Verilog. I want to convert a parallel data to serial, but without success. What are the bullshit and flaws in my code?
----- TOP------------------
`timescale 1ns / 1ps
module Serializer(
    input  wire clk,
    input  wire [7:0] in_data,
    input  wire valid_data,
    output reg out_data
    reg [7:0] temp_data;
    always @(posedge clk)
    begin
    temp_data <= in_data;
        if(valid_data == 1)
        begin
            temp_data <= {1'b0, temp_data[7:1]};
            out_data <= temp_data[0];
        end
    end
endmodule
-----TESTBENCH-------------
module tb_serializer();
reg tb_clk = 1'b0;
reg [7:0] tb_in_data = 8'b01010011;
reg tb_valid_data =1'b1;
wire tb_out_data ;
//Clock
always begin
tb_clk = ~tb_clk;
#5;
end
//Testbench Connection
Serializer DUT(
    .clk(tb_clk),
    .in_data(tb_in_data),
    .valid_data(tb_valid_data),
    .out_data(tb_out_data)
//Serializer
initial begin
#200;
tb_in_data = 8'b11001111;
end
endmodule
The simulation waveform should indicate the bull**** happening!
1. The bits should be shifted out serially on every rising edge of the clock, where are you doing it?
2. valid_data is not being driven in the TB
3. Search "parallel to serial data conversion + Verilog"
Code Verilog - [expand]
8
9
    begin
        temp_data <= in_data;     //<<<<< this is done in parallel with the if statement below
        if(valid_data == 1)
        begin
            temp_data <= {1'b0, temp_data[7:1]};  //<<<<< simulator always does this as valid_data is always 1
        end
    end
Since the two statements commented above are always done at the posedge of the clock the result is only the if statement assignment is effectively completed.
You need a separate load signal or use the inactive state of valid, i.e. !valid_data, to perform the temp_data <= in_data; assignment.
8
9
10
11
    begin
        if (!valid_data) begin    // load in_data into temp_data when valid_data == 0
        end
        else if (valid_data == 1)      // enables the shift register
        begin
        end
    end
I would rename the signals to reflect what they are actually doing:
valid_data >>> shift_loadn
temp_data >>> shift_reg
out_data >>> serial_out
