afesheir
Member level 1
![Member level 1](/styles/images/ranks/dlevel1.gif)
Dear everyone ..
I'm trying to program PIC16F877A using JDM serial programmer and IC-PROG. I've got a successful verification message from IC-PROG, so I removed the PIC from JDM and installed it on bread board with appropriate Vdd on Pin 11 & 32 and Vss on Pin 12 & 31. I've connected 8MHz crystal with two capacitors on pins 13 & 14 and pulled MCLR pin up to Vdd. The problem that there is no output at all (the hex file is actually a simple flasher program just for test)
Any help or support is very appreciated and most welcome![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Regards
Regards
