basic question on AM modulation
elecfan
Member level 1
Member level 1
Earth
can we consider AM modulation as multiplication of two signals?
Clearly yes, see this explanation https://en.wikipedia.org/wiki/Amplitude_modulation
Two simple multiplication cases can be distinguished
y(t) = [1 + m(t)]*c(t) (regular AM with carrier, as used in broadcast)
y(t) = m(t)*c(t) (double-sideband modulation with suppressed carrier)
in the first case we will have:
y(t) = c(t) + c(t).m(t) (multiplication of the two or convolution?)
and also in the second case.
in the first case we will have wc, (wc+wm) and (wc-wm) in frequency band
and in the second case just wc+wm and wc-wm.
is this right?
It is multiplication.
y(t)=[ 1 + m(t)].c(t)
m(t)= cos(2*pi*fm*t)
c(t)= cos(2*pi*fc*t)
Substituting the above in y(t), and applying a trigonometric identity, you can find terms that contain fc+fm and fc-fm.
The purpose of this is to frequency translate the message signal. The way to do it is multiplication.
