hey, its very simple.
single &, | represent bitwise operators. while double & ,| ( ie && , || ) represents logical operators.
o/p of logical operators is a single bit. i.e. 1 (if true, non-zero) or 0 (if false , zero).
In ur case both "a" and "b" are non zero, hence the o/p is TRUE (in digital terminology it is 1 )
The && operator is only 2-state. It is either 1 or 0 depending on the operands.
The & operator is 4-state. It can be 1, 0, X or Z depending on the operands.
&& is called a logical operator because both sides need to be 1 in order for the output to be 1. In all other cases, it is 0. So if you had a = 0010 and b = 0110,
a && b would give you 0 (or compile error depending on your synthesizer).
A better (and proper) way to use && would be:
(a == 0010 && b == 0110)
& is a bitwise operator because it takes the bitwise AND of both operands.
