Basic problem with PSpice
balta
Newbie level 6
Newbie level 6
Hi, I am new with PSpice, and stuff, and I have project for Linear Electronics. Teacher gave us files for NMOS and PMOS transistors: for both of them two files: one with extension .OLB and another with extension .lib. I am using Orcad 9.2 and when I try to simulate basic circuit(which I draw in Capture) just with one MOS, VDD and GND it says:
Model MOD03N used by M_Q1 is undefined
I entered all parameters PD, AD, PS, AS, W, L, and I added teachers library from option: place part-> add library -> add CMOS0_3.OLB
Any help is welcome. Thnks in advance, Milan
The *.lib file must also be referenced in library settings.
I entered in part->edit properties->implementation path *.lib file, but nothing changed. Thank u anyway, I will continue trying.
The assumption was, that MOD03N is defined in the *.lib file. It may be simply missing.
    balta
I open it in ordinary editor and it says:
* LIBRERIA PER STUDENTI CREATA DA GIANLUCA GIUSTOLISI *
* IL 11 GIUGNO 2004 *
* TRANSISTORI MOS DA 0.3UM *
* VER. 2.0 *
* PARAMETRI PER IL CALCOLO DELLE AREE E DEI PERIMETRI DI SOURCE-DRAIN *
* Lmin =0.3E-6 *
* Wmin =1.0E-6 *
* Lj =1.1E-6 *
* AD=AS =W * Lj *
* PD=PD =W + 2Lj *
.MODEL MOD03N NMOS LEVEL=7
* *** Flags ***
+MOBMOD =1.000e+00 CAPMOD =2.000e+00
+NOIMOD =3.000e+00
* *** Threshold voltage related model parameters ***
+K1 =5.0296e-01
+K2 =3.3985e-02 K3 =-1.136e+00 K3B =-4.399e-01
+NCH =2.611e+17 VTH0 =4.979e-01
+VOFF =-8.925e-02 DVT0 =5.000e+01 DVT1 =1.039e+00
+DVT2 =-8.375e-03 KETA =2.032e-02
+PSCBE1 =3.518e+08 PSCBE2 =7.491e-05
+DVT0W =1.089e-01 DVT1W =6.671e+04 DVT2W =-1.352e-02
* *** Mobility related model parameters ***
+UA =4.705e-12 UB =2.137e-18 UC =1.000e-20
+U0 =4.758e+02
* *** Subthreshold related parameters ***
+DSUB =5.000e-01 ETA0 =1.415e-02 ETAB =-1.221e-01
+NFACTOR=4.136e-01
* *** Saturation related parameters ***
+EM =4.100e+07 PCLM =6.948e-01
+PDIBLC1=3.571e-01 PDIBLC2=2.065e-03 DROUT =5.000e-01
+A0 =2.541e+00 A1 =0.000e+00 A2 =1.000e+00
+PVAG =0.000e+00 VSAT =1.338e+05 AGS =2.408e-01
+B0 =4.301e-09 B1 =0.000e+00 DELTA =1.442e-02
+PDIBLCB=3.222e-01
* *** Geometry modulation related parameters ***
+W0 =2.673e-07 DLC =3.0000e-08
+DWB =0.000e+00 DWG =0.000e+00
+LL =0.000e+00 LW =0.000e+00 LWL =0.000e+00
+LLN =1.000e+00 LWN =1.000e+00 WL =0.000e+00
+WW =-1.297e-14 WWL =-9.411e-21 WLN =1.000e+00
+WWN =1.000e+00
* *** Temperature effect parameters ***
+AT =3.300e+04 UTE =-1.800e+00
+KT1 =-3.302e-01 KT2 =2.200e-02 KT1L =0.000e+00
+UA1 =0.000e+00 UB1 =0.000e+00 UC1 =0.000e+00
+PRT =0.000e+00
* *** Overlap capacitance related and dynamic model parameters ***
+CGDO =1.300e-10 CGSO =1.200e-10 CGBO =1.100e-10
+CGDL =1.310e-10 CGSL =1.310e-10 CKAPPA =6.000e-01
+CF =0.000e+00 ELM =5.000e+00
+XPART =1.000e+00 CLC =1.000e-15 CLE =6.000e-01
* *** Parasitic resistance and capacitance related model parameters ***
+RDSW =3.449e+02
+CDSC =0.000e+00 CDSCB =1.500e-03 CDSCD =1.000e-03
+PRWB =-2.416e-01 PRWG =0.000e+00 CIT =4.441e-04
* *** Process and parameters extraction related model parameters ***
+TOX =7.575e-09 NGATE =0.000e+00
+NLX =1.888e-07
* *** Substrate current related model parameters ***
+ALPHA0 =0.000e+00 BETA0 =3.000e+01
* *** Noise effect related model parameters ***
+AF =1.3600e+00 KF =5.1e-27 EF =1.000e+00
+NOIA =1.73e+19 NOIB =7.000e+04 NOIC =-5.64e-13
* *** Common extrinsic model parameters ***
+LINT =-5.005e-08 WINT =9.4030e-08 XJ =3.000e-07
+RSH =7.000e+01 JS =1.000e-05
+CJ =9.400e-04 CJSW =2.500e-10
+CBD =0.000e+00 CBS =0.000e+00 IS =0.000e+00
+MJ =3.400e-01 N =1.000e+00 MJSW =2.300e-01
+PB =6.900e-01 TT =0.000e+00
+PBSW =6.900e-01
.MODEL MOD03P PMOS LEVEL=7
* *** Flags ***
+NOIMOD =3.000e+00
+K1 =5.9959e-01
+K2 =-6.038e-02 K3 =1.103e+01 K3B =-7.580e-01
+NCH =9.240e+16 VTH0 =-6.915e-01
+VOFF =-1.170e-01 DVT0 =1.650e+00 DVT1 =3.868e-01
+DVT2 =1.659e-02 KETA =-1.440e-02
+PSCBE1 =5.000e+09 PSCBE2 =1.000e-04
+DVT0W =1.879e-01 DVT1W =7.335e+04 DVT2W =-6.312e-03
+UA =5.394e-10 UB =1.053e-18 UC =1.000e-20
+U0 =1.482e+02
+DSUB =5.000e-01 ETA0 =2.480e-01 ETAB =-3.917e-03
+NFACTOR=1.214e+00
+EM =4.100e+07 PCLM =3.184e+00
+PDIBLC1=1.000e-04 PDIBLC2=1.000e-20 DROUT =5.000e-01
+A0 =5.850e-01 A1 =0.000e+00 A2 =1.000e+00
+PVAG =0.000e+00 VSAT =1.158e+05 AGS =2.468e-01
+B0 =8.832e-08 B1 =0.000e+00 DELTA =1.000e-02
+PDIBLCB=1.000e+00
+W0 =1.000e-10 DLC =2.4500e-08
+WW =1.894e-16 WWL =-1.981e-21 WLN =1.000e+00
+WWN =1.040e+00
+AT =3.300e+04 UTE =-1.300e+00
+KT1 =-5.403e-01 KT2 =2.200e-02 KT1L =0.000e+00
+PRT =0.000e+00
+CGDO =8.600e-11 CGSO =8.600e-11 CGBO =1.100e-10
+CGDL =1.080e-10 CGSL =1.080e-10 CKAPPA =6.000e-01
+RDSW =1.033e+03
+CDSC =2.589e-03 CDSCB =2.943e-04 CDSCD =4.370e-04
+PRWB =-9.731e-02 PRWG =1.477e-01 CIT =0.000e+00
+TOX =7.754e-09 NGATE =0.000e+00
+NLX =1.770e-07
+AF =1.48e+00 KF =8.5e-27 EF =1.000e+00
+NOIA =1.52e+18 NOIB =7.75e+03 NOIC =5.0e-13
+LINT =-7.130e-08 WINT =3.4490e-08 XJ =3.000e-07
+RSH =1.290e+02 JS =9.000e-05
+CJ =1.360e-03 CJSW =3.200e-10
+MJ =5.600e-01 N =1.000e+00 MJSW =4.300e-01
+PB =1.020e+00 TT =0.000e+00
+PBSW =1.020e+00
I found a problem. I didnt properly loaded PSpice model, thanks everyone.
