David83
Advanced Member level 1
I am using the algorithm presented in " Sparse channel estimation via matching pursuit with application to equalization", for channel estimation as following:
However, when I use this channel estimate to find the BER, I get an error floor, whereas there is no error floor in perfect CSI curve. WHY?
Thanks in advance
Np=24;
Nd=128;
L=19;
TapsL=[1 10 12 19 20];
S=length(TapsL);
Index=zeros(S,1);%Tap Locations
c=zeros(L+1,1);
cHatMP=zeros(L+1,1);
hHatMP=zeros(S,1);%Taps CS Estimates
h=(1/sqrt(2.*(S))).*(randn(S,1)+1i.*randn(S,1));
c(TapsL)=h;
%Channel Estimation
np=(1/sqrt(2*SNR(ii))).*(randn(Np+L,1)+1i.*randn(Np+L,1));
n=(1/sqrt(2*SNR(ii))).*(randn(Nd+L,1)+1i.*randn(Nd+L,1));
xpCP=[xp(end-L+1:end);xp];
yp=filter(c,1,xpCP)+np;
yp(1:L)=[];
cHatLS=inv(transpose(conj(A))*A)*transpose(conj(A))*yp;
CHatLS=fft(cHatLS,Nd);
WZFLS=1./CHatLS;
WMMSELS=conj(CHatLS)./(abs(CHatLS).^2+1/SNR(ii));
for ss=1:S
max=0;
for pp=1:L+1
if ss>1
set=0;
for mm=1:ss-1
if Index(mm)==pp
set=1;
end
end
if set==0
Proj=(abs(transpose(conj(A(:,pp)))*yp)^2)/norm(A(:,pp))^2;
if Proj>max
max=Proj;
maxIndex=pp;
end
end
else
if Proj>max
max=Proj;
maxIndex=pp;
end
end
end
hHatMP(ss)=transpose(conj(A(:,maxIndex)))*yp/norm(A(:,maxIndex))^2;
Index(ss)=maxIndex;
yp=yp-((transpose(conj(A(:,maxIndex)))*yp*A(:,maxIndex))/norm(A(:,maxIndex))^2);
end
cHatMP(Index)=hHatMP;
Thanks in advance
