Rudy S
Newbie
We are going to have students build a simple series and a simple parallel circuit with two D batteries, a buzzer, a motor and a light bulb. We have tested several different buzzers and motors with even more voltage than 3 volts and in any voltage scenario for all three devices the only device that works in series is the buzzer. Can you explain what is happening? I even tried hooking all three in series to 18 volts and only the buzzer works. Anything you can share would be helpful. Below is an image summarizing some of our early testing.
