Basic C programming question
arm_learner
Member level 2
Member level 2
Basic C Programming
#define Z 1
#if Z
A
#else
B
#endif
I want to know Z will select A or B?
Thz!
Re: Basic C Programming
A will be chosen.
0 will be mapped to FALSE.
Anything else will be mapped to TRUE.
it will certainly select A
Basic C Programming
certainnly A is chosen!
WE CERTAINLY GET A BECAUSE WE HAVE DEFINED Z=1 .
Basic C Programming
It will definitely be A.
You defined Z=1
if Z=1 -> A
else if Z= 0 -> B
s2c97
As everybody else stated, It will select A. The reason being simple that the preprocessor will simply replace 'Z' with '1' wherever it encounters Z. So the preprocessor output will be like
#if 1
A
#else
B
#endif
which obviously results in A.
DigitalScholar
Basic C Programming
Basic C Programming
This is a very simple question.
A will be chosed.
This will help some one to develope code during degugging. And than deleting
the code of the 0 part.
arm_learner said:
#define Z 1
#if Z
A
#else
B
#endif
Thz!
There's another way to do this which I personally prefer.
#define DEBUG // use #undef DEBUG if not in debug mode
#if defined (DEBUG)
A
#elseif
B
#endif
or
#undef DEBUG
#if !defined (DEBUG)
B
#elseif
A
#endif
