Bash scripting syntax and TCL
tahirsengine
Member level 3
Member level 3
Germany
I am in learning phase of both TCL and Linux Bash scripting.
I have noticed that many of the syntax of TCL are very much similar to Bash scripting.
So is there any connection between the two, as Linux I use as an operating system and TCL I use to automate software processes.
It is not surprising because the frontends are similar for a reason. The backends are very similar because they use the same system calls.
Scripting languages are simpler to process compared to other compiler languages. Normally they will also use Tk (tool-kit) for a good look!
You see the dependencies when you download the packages and see how they are related.
