sir how to give the base number 3, 4, 5, 6, 7, etc., to verilog coding. i try the base number multiplier i have a doubt on how to write on base number? oct number will give on waveform but what about other base value.
I don't see how octal number are related to a "waveform". Neither what it means "to give the base number 3, 4, 5, 6, 7, etc., to verilog coding"?
If you are referring to based integer literals, Verilog doesn't support other bases then binary, octal, decimal, hexadecimal. How about giving an example what you want to achieve?
