Bandwidth of this LC filter
EDA_hg81
Advanced Member level 2
Please let me know how to calculate the bandwidth of this LC filter?
Thanks.
Without specifying a source and load impedance and possibly inductor Q, you can't calculate a bandwidth.
    EDA_hg81
Hi EDA_hg81,
Or you means the cut-off frequency?
K.
    EDA_hg81
karesz said:
Hi EDA_hg81,
K.
Ohh - is there a difference between bandwidth and "cut-off"?
    EDA_hg81
Badwidth is for me only for bandfilters/rejectors & these is a TP-oder?
Here is Q no matter. Sind wir bitte einig?
K.
    EDA_hg81
K.
No, sorry. For my understanding - and this is in agreement with most of all relevant textbooks - a low pass has a usable bandwidth which equals the cut-off frequency.
Concerning Q: The cut-off frequency as well as the filter shape (low pass approximation) depend, of course, on the inductor Q (and the source impedance).
    EDA_hg81
The circuit doesn't clearly show a low pass, but I understand now, that it's meant as such. Cut-off is 1/(2pi√LC).
    EDA_hg81
Thank you all.
I am wondering it is Low pass filter?
Why he used two caps?
Yea LvW,
Clear; you are correct with shape factor vs Q, but how plays it pls to cut-off frequency?
K.
    EDA_hg81
My question is :
The serial data are sent out to a bluetooth module for being transfered out.
Should this data line be connected with a lowpass filter in series?
The drawing at the first post shows the power filtering.
Thanks
Hi & Tnx!!
Maybe you can up load more of your ciruit pls:), not only a smal portion?
K.
This is the only I have.
The rest of schematic only show the Module interfaces.
karesz said:
Yea LvW,
K.
It is really simple to calculate the transfer function and to verify that each part determins the frequency behaviour and the cut-off frequency - even a parasitic resistance of the lossy inductor.
Transfer Function from 3.3V point to output across parallel capacitor at Test Point (TP21) is
1/(1+S^2 LC)
where
C = C26 + C27
L = 1uH
Hi kokabanga,
perhaps you have overlooked that - from the start of this topic - the possible influence of a finite inductor Q (loss resistance) has been discussed.
Sorry, but is all these with Q in them case not only an "academical" aspect pls?
K.
