ashwini1
Member level 1
I have a simple model, in that i am adding 3 sine waves of 5Hz, 10Hz and 20Hz frequencies. The resultant wave, i am passing it through a bandpass filter which has to pass only frequencies between 8-12 Hz and block rest all. But which is not happening. For the same i am using the bandpass filter block of signal processing blockset.
I tried to set the frequencies both in normalized way as well as normal way (using Hz).
At the output spectrum i will see peak at all the 3 input frequencies. But i suppose to get peak at only desired freq.
Can anyone help me in setting the parameters of bandpass filter.
Thanks,
Ashwini
Thanks,
Ashwini
