vrefdesigner
Newbie
Hi everyone,
I'm designing an opamp-based beta-multiplier bandgap voltage reference with enable for thesis. However, I encountered a problem when enabling the vref from shutdown state (EN=1) to active state (EN=0). Please see simulation attached below.
As you can see, vref settles at 0.9V initially before fully settling to the correct value. I would like to know what the possible causes of the problem are. I'm thinking this is due to the charging of the BJT's parasitic caps and/or input pair's parasitic caps, but I'm not entirely sure/convinced it is the reason.
Info you may want:
* 8:1 BJT (5x5 unit area) ratio
* I_bjt=2uA
Bandgap vref architecture for reference
Info you may want:
* I_bjt=2uA
