kokabanga
Member level 5
By simply omitting R1 and R2, reducing the band gap circuit to a basic PTAT generator. See Razavi Figure 11.19 versus 11.39So then how can I implement a temperature sensor based on this architecture? Any guidance will be helpful.
logic behind this statement? Where did you get the equation now?It is not possible to remove R1, R2 as they are involved in generating the PTAT part of the bandgap output voltage as seen in the equation below.
I think that is formula for output voltage of bandgap, which is independent from temperature and it got from assumption that Va = Vb.It is not possible to remove R1, R2 as they are involved in generating the PTAT part of the bandgap output voltage as seen in the equation below.
