whlinfei
Member level 2
Hi All,
I have a bandgap reference circuit, which works fine in simulation. (Both DC temperature sweep and transient sweep give satisfactory results.)
As this is my first fabrication, I am a bit concerned about the start-up and also the stability of the circuits.
startup
the startup circuit I used is the one based on capacitor. such cap is connected to Vdd and a NMOS gate. once the circuit is functioning, the gate of aforesaid NMOS will be pulled down, i.e. discharged the gate capacitance and the capacitor.
It is basically a standard capacitor based startup circuit.
The other concern of mine is the diode. supposedly it is biased around 0.65 or 0.7 So it is on at that point. But I don't know how I can ensure that it is actually on. Because even Vbe is less than 0.7 or 0.6, the diode can still conduct current.
I want to ask if there is any standard tests for bandgap reference and its startup circuit ?
What are the special consideration for them ? what is the usual problem after fabricatioin ?
Thanks in advance .
Rgds, whlinfei
startup
Thanks in advance .
Rgds, whlinfei
