Bandgap: 10 ppm/Celsius
crystalballs
Member level 1
Member level 1
bandgap reference ppm
Hi all,
I have to design a bandgap circuit (curvature compensated I guess...) to reach the performance of:
10 ppm/^C.
Usually, I calculate the "ppm/^C" as follows:
PPM = 1000000 * Vbg(T) / Vbg(@25^C) [ppm/^C]
Please, do you have some advices about the bandgap architecture (i.e. the circuit) to use?
Thanks in advance.
CBs.
how to calculate ppm of bandgap
There are some approaches having about 0.1% from -25...125°C
look for the following patent
US7411380
also Stefan Marinca have a good bandgap reference in his newest patent
US7543253
10 ppm/celsius to ppm/k
0.1%/Celsius is equivalent to 1000ppm/Celsuis.
That's, to much for me...
Thanks anyway!
CBs
calculation of ppm/celsius
NO!
it is 6.6ppm/K in the best case
take a look for your self....
[/img]
ppm calculation band gap reference
it depends on your technology. Initially follow some simple bandgap structures and keep improving it till achieve your spec.
Please, take a look at the following papers:
(a) A CMOS piecewise curvature-compensated voltage reference
Lai xinquan, Xu Ziyou, Li Yanming, et all. MIcroelectronics Journal. Elsevier.
(b) A single Trim CMOS Bandgap reference with a 3 sigma inaccuracy of +-0.15% from -40 to 125. ISSC 2010.
Guang Ge, Cheng Zhang, et all.
Depends upon process, modelling etc
But typically you would need some sort of curvature compensation.
A typical trimmed BGap would have ~100ppm variation.
Note, I don't understand 10ppm/C. does that mean 10ppm*100C = 1000ppm. That is pretty easy to achieve. or does it mean 10ppm over the temp range. I am guessing the latter.
1000ppm = 0.1%. This is a good result for a bandgap over all temperature range.
crystalballs, I think your ppm/°C calculation is off.
10e6•[1/Vbg(25°C)]•[ΔVbg]/[Δ°C]
