Bandgap @ 0.9 and 2.1 V
benslama ahmed
Newbie level 6
Newbie level 6
Hi friends
I have designed a bandgap reference without OPA at 1.2V ,Now i would have a reference at 0.9 and 2.1V
please help
thx
I didn't understand your meaning.
1. U designed a BGR at 1.2V power supply, and now u want the BGR still work at 0.9V and 2.1V power supply.
2. U designed a BGR at 1.2V power supply, and now want designed another BGR to work at 0.9~2.1V power supply.
Or u want others. Please talk us other details, such as the output of BGR, process etc.
I want a bangap wich generate a Vout=0.9V and 2.1V
the power supply is Vdd=3V
thx
bangap generates 1.2 V
for other reference voltages you need opamp and resistors
It seems you are using 0.35 technology?
@pixel: op-amps are not necessary for non-bandgap references
ok.. i thought on standard bangap with bipolars...
Which non-bandgap reference can give 2.1V ? Usually thoose with mosfets are at ~500 mV
You can refer to Problems 11.17 of Razavi's textbook.
Widlar referece may help you. You can derive a referece voltage at 2.1V first, then divide it with res to get 0.9V. This may be a relative low cost solution, however more res means more noise.
ELE
hi friends
i have some problem to design the resistor divider
it works at big values of R1 and R2 and i will have some problems to implement it.
i need help
regards
