ddis
Member level 2
hi all,
i have made a center tapped balun structure in hfss using metal layers 6, 5 & 4. It is of interleaved type i.e. primary & secondary winding are formed on the same metal layer(here metal 6 to achieve high value of Q ).
the real problem is how to do its analysis by using lumped ports in driven terminal mode & extract the equivalent ckt model parameters.
Does anyone have a solution over this??????
Thanks in Advance.......
