Zander_ua
Newbie level 6
Hello everyone!
I've the following problem: I use balun for the single ended-to-differential transformation, but the self resonanse frequency of the primary winding is almost at my working frequency- 7.75GHz(working - 7.7GHz). Can I use such transformer? Someone says, that normally recommended to use inductor or transformer no higher than 3/4 of its self-resonanse frequency.. - why is that (is the constant inductance value plays here the main role)? Can you suggest me some literature were its explained?
Thank you!
Thank you!
