Balanced audio < -> unbalanced audio convertors
spktu
Member level 5
Member level 5
balanced to unbalanced ina134
What IC should I use to make a "unbalanced audio -> balanced audio" and "balanced audio -> unbalanced audio" convertors?
balanced audio to unbalanced
Many ICs,such as TI's DRV134,DRV135 for "unbalanced audio -> balanced audio" and INA134,1in137 for "balanced audio -> unbalanced audio" convertors?
ynhe
    spktu
balanced audio to unbalanced audio circuits
Check SSM2141, SSM2142 and SSM2143 from Analog Devices. These should fulfil your needs.
Rgds,
Aslak
unbalance to balance audio drv134
Texas Instruments' DRV134 is quoted as " IMPROVED REPLACEMENT FOR SSM2142" in DRV134 datasheet 8O
unbalanced to balanced drv135 drv134
Can You advise the same as DRV and INA,but wita single polarity power supply.
