studystudystudy
Member level 1
the back to back zener diode is used to limiter the voltage across. but i don't understand why resistor is needed here. please see the attachment.
the explaination i found is the resistor is served to impede the return charge drain current rate when one or both zener diode are operational.
please explain how the resistor can impede the return charge drain.
i try to understand it, but still don't understand
your help will be deeply appreciated. thank you
