mirror_pole
Member level 3
Hello guys,
I have a question about the working mechanism of a back to back MOSFET configuration. I just dont understand how this setup which is used as a bidirectional switch works. If i take this Ic for example i assume that my max voltage potential at the common source terminal is equal to Vs=Vout+Vf with Vf being the forward voltage of M2 body diode. So to turn on both FETs Vgs>Vth => Vg>Vth+Vout+Vf is needed. But what about the Vds? In case of M1 if i apply an input voltage greater then the source potential it will conduct, but what about M2? From my understanding the current is flowing from drain to source but in the case of M2 it is "reverse biased", so how is M2 even able to conduct? Through the body diode of M2?
