back-end adc in pipelined adc
ljy4468
Full Member level 4
Full Member level 4
South Korea
hi all~
I'm designing 12b 80M pipeline ad
and there are lots of problems........
I want a question about B.E. a/d.
i use 1.5bit resolution per stage.
and B.E. ad is 2bit flash a/d
And Can i use 3bit flash or 4bit flash AD in back-end???
If so, what's the drawback??
and if i made a 4bit pipeline,(1stage(1.5bit) + 3bit flash)
output will
00 <-first stage digital output
+ 000 <-3bit flash output code
0000 <-final output
is it right???
I think you are right, but you have to design a 3bits flash adc, and you also have to design the comparators which are more stringent .
why not 1.5+1.5+2? i think it is better!
regards
THNKS TO YOUR opnions.
but, tuza2000,
why is 1.5+1.5+2 is better?
please tell me why.
thanks
in idea, you can design any bits flash adc.
But it is trade of power, speed, bits and so on.
maybe the simplest is 1.5bits every stage.
ljy4468:I think the digital correction is better.
and 1.5bit/stage is the simplest.
regards
