MuroSamuro
Member level 4
Hello,
Does axial ratio is sufficient to determine on whether an antenna is circulary polarized?
If you consider two orthogonal E field (say x and y with the same amplitude) componnents without 90 degress phase shift, the axial ratio would still be 1. If so, why does people state that axial ratio determines circular polarization by itself?
Thanks
Thanks
