AVR (mega64) and mmc interface
jakky
atmega mmc
I have the mega64 and mmc so i need to interface those can any one send me the c source code and the circuit at
Thank you for help.
jakky_thai(at)hotmail.com,jakky_thai(at)yahoo.com
avr mmc
Thanks Rafael.
I gof an idea about the site that u post. but i'm use the maga64 , do u have example?
Thanks
avr mmc interface
Thanks Artem
I will try that u post and the result i will be post after i tried.
mmc + avr
Ulrich Radig source is just readonly fromm mmc/sd as far as I know.
What compiler are you using ?
sd avr
speaking frankly , i did not reused this code, but suppose that it works .
Having look to mmc.h and mmc.c i noticed following functions already implemented in this projects :
(**broken link removed**)
inline U08 mmc_read_byte(void);
inline void mmc_write_byte(U08);
extern void mmc_read_block(U08 *,U08 *,U16);
extern U08 mmc_init(void);
extern U08 mmc_read_sector (U32,U08 *);
extern U08 mmc_write_sector (U32,U08 *);
extern U08 mmc_write_command (U08 *);
extern U08 mmc_read_csd (U08 *);
extern U08 mmc_read_cid (U08 *);
