Elimathew
Member level 5
hey guys im using atmega 168A -pu im beginner with avr i have some basic doubts as to can i use 20mhz crystal and if so ive done the fuse settings can you please tell me if its right spien-programmed(logic 0) brownout programmed to 4.3V BODLEVEL1=programmed(logic 0) BODLEVEL0=programmed(logic 0) BOOTSZ1=programmed(logic 0) BOOTSZ0= programmed(logic 0) programmed CKSEL3 rest all are unprogrammed
lowerfuse byte =0xF7
higher fuse byte=0xDC
guys ive used engbedded fuse bit calculator i just needed to be confirmed that my settings are right
