iceblu3710
Member level 3
I recently purchased an Arduino with an atmega1280 on it. I did not get it to use the Arduino IDE but just as a handy board to use with AVR Studio and my Dragon.
I purchased a new computer around the same time and it is running windows 7 64bit, I downloaded AVR Studio 5.1 and plugged in my Dragon. I upgraded to the latest firmware as it forces you to do. I then connected the Dragon to the Arduino and I get the following error:
I have verified the ribbon cable pinouts are the same on both ends and have continuity. Pin 1 goes to Pin 1 and so forth. AVR Studio can read the 5.0V on the sense line but that is it.
I then installed libusb-win (1.6.2.0) and used avrdude to get a more descriptive error: pasebin output
I have tried to wire up an atmega8 and atmega128 on breadboard with ISP and JTAG connections and I get the same errors as above but it makes more since to troubleshoot the PCB to PCB connection issue to eliminate any mis-wireings I may have.
Any idea where to start looking for the problem???
[ERROR] Failed to enter programming mode. ispEnterProgMode: Error status received: Got 0xc0, expected 0x00, ModuleName: TCF (TCF command: Device:startSession failed.)
