banjo
Advanced Member level 2
Is any one using the Virtex-4 board from AVNET? Have you figured out how to reprogram the on-board FLASH? The Xilinx eval boards have Compact Flash cards that can be removed for programming. The AVNET board has soldered on FLASH.
My first thought was that this would be done via the serial port with a utility bit file for the FPGA. However, thus far, I have not found any documentation about this.
Any hints on how to do this would be greatly appreciated.
Thanks.
---- Steve
Thanks.
---- Steve
