SDM(ix)
Newbie
Hi guys.i'm new in edaboard
I'm in designing car AVL with SIM908 module.I have a problem with power unit.The system powered with two power sources,external power from car and the other is internal 3.7 Li-Ion battery.The SIM908 has a built-in battery charger(Very Cool!).I want to connect the battery to VBAT pin and external voltage from switching regulator(LM2596T-ADJ) to VCHG pin of module.
The main power source of module and subsystem(micro,lcd,...) is internal battery and external power will charge the battery.
Everything is OK!
But...
The problem is when the battery is damaged or accidentally removed...
If in normal operation of system, internal battery removed,the system must be alive and work with external power.
Any body know about that the SIM908 power can be produced from VCHG pin?(The regulator circuit is designed for producing 2A current) or i have to design the hardware to switch the power source from internal battery to external power?
Thanks for your time.
Saeid
Everything is OK!
But...
Saeid
