PlanarMetamaterials
- Joined
- Jun 13, 2012
- Messages
- 1,476
- Helped
- 407
- Reputation
- 818
- Reaction score
- 385
- Trophy points
- 1,363
- Location
- Edmonton, Canada
- Activity points
- 9,960
I'm new to electronics and am trying to design a sub-nanosecond 50V pulse generator via an avalanche transistor. I've chosen Zetex's FMMT413 transistor as it looks perfect for the task. I designed the following circuit:
Which, as far as I can tell, is pretty standard.
However, I cannot get this circuit to produce an output (I'm using a 5 GHz scope connected to Vout). I've tried adjusting Vin from 60V to 120V, and applied a square wave input to the trigger. As far as I can tell, all the components are working properly and I've measured proper voltages at every node. I've tried three different transistors just in case, and have tried replacing C11 with a 5 nF cap as per the datasheet and application note. The variable resistor R6 is maxed at 100 kOhm, adjusting to a lower value doesn't make a difference.
Any suggestions as to how to obtain the desired output?
