Automotive Embedded Systems question
kishorekumar_ms
Member level 5
Member level 5
hi all,
Can u tell basic topics which one should be known when he is working in automotive embedded systems? I will be happy if u even explain these topics.
Thanks & Regards,
M.S. Kishore Kumar.
You need to know about the CAN bus and the LIN bus. Tools for CAN are supplied by Vector.
https://www.vector.com/vi_canalyzer_en.html?gclid=CLTEqMTe-JgCFQrFGgodMiWplw
You can download demo software to take a look.
The C code you write has to be MISRA compliant. You need to buy the book,
'Guidelines for the use of the C language in critical systems'
to learn the MISRA rules.
For static analysis and checking for MISRA compliance you need a tool like Gimpel PC Lint.
Other than that, it's just C code hacking.
