Automatic Water Level Controller for Lifting Water from Underground Tank to Overhead
yasir23
Member level 1
Member level 1
this ckt is working.but problem is that its not showing correct level of water at seven segment display at the run time until i pressed the reset button. when i pressed the reset button so it show the correct level of water but buzzer will start sound then i dip the lower limit of sump then the buzzer gets off.
plz help i want to implement in my house.
the coding is here
  • coding.txt
    mursudha
i will suggest u to share the proteus file as well as the hex file so that we can tets it!
